I think the atmb is removable from it's bracket ? I was hoping the bracket would be compatible with the MangoOur ATMB does work mounted on the dotted bit by the rear mirror, our first job when the mango one arrives, will be to try and remove the old one, any tips?
It is , we have both.I think the atmb is removable from it's bracket ? I was hoping the bracket would be compatible with the Mango
Different bracket unfortunately.I think the atmb is removable from it's bracket ? I was hoping the bracket would be compatible with the Mango
I asked on my own thread Annie and someone suggested going round with a razor blade and then using a bit of nail varnish for the remains. I have also googled it and a suggestion I’m going to try first is to use an old credit card instead of the razor blade, sounds safer! Also do it when the sun has been on the windscreen or warm with a hairdryer first.Our ATMB does work mounted on the dotted bit by the rear mirror, our first job when the mango one arrives, will be to try and remove the old one, any tips?
Our old ATMB tag and APRR ( Mango) tag brackets are the sameDifferent bracket unfortunately.
I gently twisted ours and it gradually stretched the glue and it came off. It takes a bit of effort to get it to start to twist. Scraped the residue off with a razor bladeOur ATMB does work mounted on the dotted bit by the rear mirror, our first job when the mango one arrives, will be to try and remove the old one, any tips?
My ATMB is about 7 years old and although the bracket is the same as the Emovis tag it’s different to the new Mango tag that’s just arrived. The old ones are long and thinner.Our old ATMB tag and APRR ( Mango) tag brackets are the same
They’ve obviously decided to new and improve it, it’s the same company as you know.Ah, different tag to the APRR one we have. My apologies if I've confused anyone.
I know Ditcha did it prior to getting the Mango tag. They are very busy enjoying Beni now so may not answer till later although the pugs won’t let them have much of a lie in!On the subject of the older APRR and ATMB tags has anyone managed to find a battery to replace the original . I've opened up my tag to check the battery type but I've looked everywhere and can't find one to replace it.
Patrick
