Mains power cut out
S/S
Swift Sundance 630L
I am hooked up to the main and no issues for two days all in the MH working well. Then power goes off try reset button nothing happens, unplug from mains and MH reconnect both and all is ok, this has happened a few times now any help much appreciated.
Really need more information.
Hooked up at home or on a campsite.. If on a site they often have limited supply which comes to question 2.
What equipment are you running ? you may be taking more power than the supply can give..
Hi. On site, running heater,TV/fire stick, using socket to charge phone. Mains post not tripping.
Have checked fuses and all ok, only tried the RCD trip to see if I had power.
Just wondering if it could be issue with the hook up lead?
How wet has it been where you are?
Moisture in the lead, or socket?
Mike.
try checking the socket from mains to van , sometimes corrosion sets in.
It could be the hook up lead
I had one fail at the bend a foot from where it connects to the van, I presume wear and tear had caused it to deteriorate.
I cut a metre off and reattached connection then all good.
I bought a new lead and keep this one as a reserve
w2f
