Any recommendations for a supplier of good quality lug crimps, the set I got from Amazon are rubbish - wrong internal diameter ?
Nope sorry I do not agree with that. The cheap hydraulic ones are not fit for purpose and do not crimp correctly. If you are having to use the smaller die it's a bodge from the start.
Largest connection I made was 35sqmm and you could hang off the lug. I put 2100watt for over 40 min through the joins and nothing got hot.
I have the hammer one, if you can get the room and the stable base, it makes very good connections. Even a small hammer is heavy enough if you hit it enough times.You may be very skilled, us mere mortals need a hydraulic tool for larger connectors…
I used this but set the crimps with a vice rather than use a hammerI would only use that as a temporary measure, or low currents. Hydraulic it’s best and safest crimp for high currents.
I've got similar to the 1st one but not had much luck with it, I think s**t lugs is the problem, so will try a different make this afternoon.For the crimp tools I use these two.
and for normal red/yellow/blue I use these;
Wissel also got the 1st ones and I think he like them? I do however use the next size down when crimping as it gives a much better crimp.
can borrow mine depending where you are, it does up to 630a supplies for work so should be ok for mh!!Any recommendations for a supplier of good quality lug crimps, the set I got from Amazon are rubbish - wrong internal diameter ?
Thanks for the offer, but crimping tools are one of the tools I like to have - my car ones are probably 30 years old, but still do a good crimp - and I'm determined to find a set that works.can borrow mine depending where you are, it does up to 630a supplies for work so should be ok for mh!!
Based near Peterborough.
They do a shit crimp if you use the specified size. Try using the next notch down on the tool. That will probably fix your issue?I've got similar to the 1st one but not had much luck with it, I think s**t lugs is the problem, so will try a different make this afternoon.
If still no better I'll gat these https://www.screwfix.com/p/ratchet-crimping-tool-7-180mm-/96561#product_additional_details_container:~:text=RATCHET CRIMPING TOOL 7" (180MM) (96561)
Well spotted, I missed that, so no I won't be getting them.The one you linked to is just for 10mm² cable though? are you not doing anything bigger than that?
are these the same onesI use a hydraulic crimper like this one:
16 Ton 8 Dies Hydraulic Crimper Crimping Tool Wire Battery Cable Lug Terminal | eBay
Find many great new & used options and get the best deals for 16 Ton 8 Dies Hydraulic Crimper Crimping Tool Wire Battery Cable Lug Terminal at the best online prices at eBay! Free delivery for many products.www.ebay.co.uk
Any crimper must deform the strands of the conductor rather than simply gripping them.
I also have one of the Clark's one for doing bigger crimps but mine has red handles. Bought it from Machine Mart.For the crimp tools I use these two.
Screwfix sell lugs not sure of the quality but they look okay also ToolstationAny recommendations for a supplier of good quality lug crimps, the set I got from Amazon are rubbish - wrong internal diameter ?
You will learn, cold weld is a safe connection in my book. I have tried various crimper and I do have a collection. Even the cheap Chinese 4-5T crimper can do better than pliers or hammer on. You need to learn to chose the dye and add strands in the lug, if necessary. I have done hundreds so far, with largest 95mm2. I have a resistance meter that can measure down to 0.001 ml ohm, yes ml ohm. You will be surprised the difference from a cold weld resistance, to hammer on.Nope sorry I do not agree with that. The cheap hydraulic ones are not fit for purpose and do not crimp correctly. If you are having to use the smaller die it's a bodge from the start.
Adding strands to the lug is a great tip. Ive had a bit of an issue with the 16mm2 die on a Chinese hydraulic not fully crimping so used the next down, 10. Adding strands would probably have sorted it probably.You will learn, cold weld is a safe connection in my book. I have tried various crimper and I do have a collection. Even the cheap Chinese 4-5T crimper can do better than pliers or hammer on. You need to learn to chose the dye and add strands in the lug, if necessary. I have done hundreds so far, with largest 95mm2. I have a resistance meter that can measure down to 0.001 ml ohm, yes ml ohm. You will be surprised the difference from a cold weld resistance, to hammer on.
Look to be exactly the same.
They are about the same as the ones that came with my crimping tool.Screwfix sell lugs not sure of the quality but they look okay also Toolstation
