Blue alarm light (31 Viewers)
KLWinton
31
79
Aberdeenshire, UK
Elddis Ecore 255
On and off for 30 years
I have a Ducato based Elddis motorhome and it has an LED in the front window pillar that flashes when it is locked and alarmed. Recently the light has stopped flashing. Is this something that I have switched off unknowingly and can it be turned back on again. TIA
Two on Tour
10,864
56,440
Elddis Autoquest 175
Since 2010
It's not possible to accidentally or program out the blue LED in the front window pillar, as this is used to indicate the flash codes used to program the alarms features and modes, so it would likely be either the LED, wiring to the LED or something within the electronics of your alarm has failed if your alarm is still arming and disarming.
Have you tried setting your alarm with the Autowatch remote, not the Peugeot remote, and opening a cab door to see if your alarm is actually working ?
4,908
9,564
Greenwich, London, UK
Hymer MLT 570
Do you know if it's a VanBitz alarm ?
If so, the blue LED's have a Bright and Dim switch.
(Dim can hardly be seen in sunlight)
There may also be switches to switch the internal PIR on/off and the cycle alarm loop (if fitted) on/off.
On a Mercedes Sprinter based van the switches are by the passengers left knee.
But location would vary depending on the base vehicle.
If it's VanBitz, then they will replace and upgrade the systems as required.
(However they are based about as far away from you as you can get, but they do have a phone!)
