Lubricants for hinges with bushes?
A Class N+B Arto 69GL
Since 2009
Our door and external lockers have hinges with bushes (teflon/nylon?).
What is the best lubricant? Silicon spray or other?
Should one remove the end caps and spray inside or externally?
TIA
Those types of bushes don't generally require lubrication.. they are self lubricating.. but a spray with PTFE will help reduce wear.. I wouldn't remove end caps .. just spray on the hinges
Ive used ptfe,silicon and some spray graphite oil. Easy to spray in gap and work hinge up and down
Aldi have GT85 lubricant spray in at the moment, it's my go to for most jobs and I think better than WD 40 ?
Jim, I had one seize on me and snap, thus my question.
Thanks all for.the answers and 4eassurance that silicone spray is fine.
Aldi furniture polish.
I do find it strange that, despite the many posts on with counter information, how many people come up with the same response of suggesting WD40 whether for lubrication, cleaning contacts, removing sticky glue, etc, etc, etc, Invariably there is something much better, and frequently, as here with plastics, it can cause an awful lot more problems than it solves. I have can's of it and use it for certain things. It's great for removing rusty nuts and bolts for example, but it's not the panacea to every maintenance task many seem to believe.
