If you do fit something like this make sure you have ventilation as the instructions and don't fit it in the shower room![]()
Fork Strut Coil Clamp Spring Compressor Macpherson Tool Set Kit Auto Garage | eBay
Thisspring compressor is designed to compress almost any types of Macpherson style coil springs in the front and the rear. Three sets of interchangeable jaws(65 to 125mm, 88 to 160mm, 125 to 215mm) are provided to fit springs found in most automotive applications.www.ebay.co.uk
To be mounted outside only the only instantaneous water heater now is the imass but its around 750 to buy which by the time you buy a space heater is getting close to combi money![]()
A great ideapersonally if budget was tight, I would pick up a used caravan and re-use the appliances, charger and other parts for the conversion, selling on what I didn't use or need
We had one of those in a Bathroom in Borneo. It was inside, sort of, as so much of bathroom was open to the elements style, it was as much outside.![]()
