I fitted an LED level indicator when I first fitted our underslung tank and extended the green wire by over 2 metres with no problem other than the usual very poor accuracy which comes as standard.Could anyone advise on the following please.I want to reposition the level indication display for my underslung LPG tank.This might mean lengthening or shortening the green wire between the tank and display.Just wondered if this would affect the calibration in anyway.
Yours must be wired up to the vehicle battery, I wired mine to the leisureWhy are these gauges wired only to work with the engine running ? must be a reason they are all the same.
Because there will be a small drain on the battery, maybe insignificant most of the time, but significant if the mh is left unused over the winter, and no solar to charge the battery.Why are these gauges wired only to work with the engine running ? must be a reason they are all the same.
I wired mine through a rocker switch next to it so you can have it on or off.Because there will be a small drain on the battery, maybe insignificant most of the time, but significant if the mh is left unused over the winter, and no solar to charge the battery.
Mine was wired to the leisure battery and had an on/off switch.Because there will be a small drain on the battery, maybe insignificant most of the time, but significant if the mh is left unused over the winter, and no solar to charge the battery.
Just ordered one and will wire it permanent live and push the switch to see roughly yeah ok very roughly how much gas I have leftMine was wired to the leisure battery and had an on/off switch.
May i ask where you ordered it from?Just ordered one and will wire it permanent live and push the switch to see roughly yeah ok very roughly how much gas I have left![]()
https://lpgshop.co.uk/livello-led-g...XmR1-OLj32APzRkHtANc9dwkRm_ZK57YaAjtNEALw_wcBMay i ask where you ordered it from?
Got mine yesterday.Hopefully fitting on Monday.Just swapped my Gasit indicator for the Livello found a permanent live from the cab battery and wired the red wire from the gauge to that used existing green and black that were wired into the old gauge. Push button shows level push again to turn off. Sorted
Sorry but this is so funnyJust swapped my Gasit indicator for the Livello found a permanent live from the cab battery and wired the red wire from the gauge to that used existing green and black that were wired into the old gauge. Push button shows level push again to turn off. Sorted
Livello is Level in Italian, you have just swapped like for like,they are both the same gauge made by the same manufacturer,just one has a sticker on it branding it .
Sorry but I find it funnyThe Livello has a built in switch so I can now check the level without having to start my vans engine every time. Nothing funny about it at all !
It is your van and your money so I would think you can do exactly what you want?The Livello has a built in switch so I can now check the level without having to start my vans engine every time. Nothing funny about it at all !
As long as you have solar, there will no problem.Just ordered one and will wire it permanent live and push the switch to see roughly yeah ok very roughly how much gas I have left![]()
