- Nov 24, 2008
- 868
- 2,168
- C Class
- Since july 2009 And Still Going Strong
I’ve just fitted an underslung gas tank to my sprinter conversion. The supplied regulator with the kit is a 30Mbar but my existing equipment documents say 37mbar should be used. I've read that the regulations changed around 2002 to the use of 30Mbar for butane and propane.
I run a Junkers water heater and even the ones sold now say 37mbar and the propex heater says a reduced pressure will mean it won’t run to maximum heat output.
The question is can I not just connect my 37mbar propane regulator to the tank outlet (via an adapter) and continue to use the same pressure that’s worked perfectly for the last 4 years.
From what I’ve read the regulator spec says EN12864 standard which says it will work with Butane/Propane and a mix off, LPG.
is there something special about the regulators that run lpg? I’m presuming not as in our RV we use lpg from the onboard tank and then via an extend a stay kit connect up a calor propane bottle, both running through the existing regulator on the onboard tank.
Photo attached of the regulator im looking to use.
Thanks for reading.
Shawn
Thanks for reading.
Shawn
