John65
In northern Portugal at the moment and need to fill with gas. The garages we have tried don’t have adapter to fit. Have we been unlucky or will it be the same everywhere? Anyone any experience of filling in Portugal.
Thanks for the reply’s the garages we have tried had the euro adapter but the thread was too small for the uk filler.
When you do get the new adaptor, would you mind putting a photo of it on here or pm me please. We are just about to enter Spain on our way to Portugal. Would be handy to have one, just in case. Kev.Problem now solved,filled with gas this morning. No prizes for guessing what my next purchase will be. Anyway thanks again for all the replies much appreciated.
Is it a problem to have the nonreturn valve? Mine has but I have not had to use it up till now. Presumably there will be a small amount of liquid gas trapped behind it but as long as I am aware of it and have proper cryo gloves I would have thought it was OK.This is the one used in Spain & Portugal, there are two types with and without a non return valve you need the one without. If you can't find one it's easy to push or drill out the valve.
This one also used in Portugal, same as France, Italy & Greece.
There is already a non return valve in you inlet sometimes causes problems filling as you get a build up of liquid gas between the two valves which makes disconnecting even more hazardous.Is it a problem to have the nonreturn valve? Mine has but I have not had to use it up till now. Presumably there will be a small amount of liquid gas trapped behind it but as long as I am aware of it and have proper cryo gloves I would have thought it was OK.
