LPG Gas
grp
yorkshire
Hymer
I know this may sound simple, buy im filling it for first time and I've watched some videos
My question is, how do i know when to stop filling?
I saw somewhere should only fill it 80%? so cant keep going until it stops
also read i should turn all isolators off while filling?
No need to turn isolators off. As far as the pump is concerned, 80%is full. You'll know when it gets to 80% because the rate of fill (and the sound of the pump)will slow right down. At which point, stop.
If your tanks are refillable ones,gasit,gaslow for example ,they will stop filling on their own at 80%. They have a float valve internally that stops the filling process.
My Gaslow system shuts off automatically at 80% and the pump stops due to the back pressure sensed by the pump.
I have an LPG tank onboard. When I fill up at the pump, I hold the button down until the display stops counting, then I give it one final push for a few seconds. It will not go beyond the 80% limit which to all intents and purposes is "full" and therefore stop pumping. It's the equivalent of the petrol/diesel pump clicking and stopping when full.
If the cylinders are empty then you know how many kg they can take. For each kg it is 1.9 litres approx.
So if your empty cylinder holds 11kg then 11*1.9 is 20.9 litres.
You will see the pump display how many litres are going in so stop when the pump slows ( when 80% point occurs) or when 21 litres has been put in, whichever happens first.
If cylinder is not empty then you are relying on the 80% cutoff as you donot know how much is in there.
As described above, you can’t go wrong, the technology prevents you going over the 80% fill level.
That 80% level is there to provide a space above the liquid petroleum enabling it to form a gas for use in your appliances.
One word of caution, use decent gloves (gardening gloves will do if nothing else is around) to avoid frost burns.
