LPG availability M25/M4 corridor (1 Viewer)
Jul 5, 2013
11,865
13,979
Since 2013
We are off from Kent to Cardiff next week going via A21, M25 and M4 and want to fill up Autogas on the way. From memory I thought there was a pump at Membury services but can't find it any more on the FillLPG app. Also the app shows that both Morrisons and Asda at Cribbs Causeway are temporarily unavailable.
Is this correct? If so can you name other sites on or close to our journey please. Many thanks for any help.
Kannon Fodda
2,882
8,785
Seek and Ye May Find
Autotrail V-line 540
I Make Schoolboy Errors!
M25 J11 Addlestone Shell. Usually about the cheapest when it has it, but can go out of stock for very lengthy periods and appears to have recently run out according to apps.
I think there is a gas supplier in Wokingham (near Reading).
Apr 26, 2015
3,304
7,982
Ottershaw
Hymer S820
First motorhome May 2021
I just checked now as it was showing temporarily out of order yesterday but it's not showing that now. An alternative might be Cove service station just off the M3 and then route across up to the M4.
RowleyBirkinQC
2,492
243,008
Dazed & Confused
Used to be LPG at the M4 J13 services, unfortunately no more. Depends how far you want to venture from M4, there’s usually LPG at Bellinger in Grove, near Wantage/Williams F1. Not that far from M4 J13 up the A34 North, depending on need/other options…
Nov 4, 2022
116
406
Hampshire, UK
Weinsberg
As Kannon Fodda says, the Addlestone one was 80.9ppl last Friday. Just beware to come back onto the M25 at the Chertsey junction as there is a low bridge just down the road going to the M25 next junction. Also there may be M25 closures that create havoc.
The place near Wokingham is Longmoor Farm Portable Gas, Park Lane, Finchampstead, RG40 4PT. It's full service, a helpful lady, Charlotte comes out and fills for you, then you pay at window. Currently showing 89ppl on myLPG.eu. I filled there a fortnight ago.
Go M25 / M3 exit at J4a, A30 turn off at Yateley, follow toward Arborfield, traverse new housing estate on right, LPG station on right.
Apr 26, 2015
3,304
7,982
Ottershaw
Hymer S820
These are the two that I normally use, both showing as having gas at the moment, Cove is near to M3 J4A.
