Lost Radio code on Autocruise tracker 2014
Maldon
C class
since 2002
Cant find my radio code. Several questions.
1. I need to change my vehicle battery will I need a Radio code?
2. If Radio code is needed, is there another way round the problem?
3. If no other way round the problem, what's the best approach to getting a radio code?
I saw on the news this morning that 50% of humans understand ape hand signals. At my age I beginning to wonder if I understand any signals,:confused: Human or Ape
I had one of these radio's/head units in our 2013 van and I did not require a radio code for a cab battery change.
Have a look at this....
If your vehicle is Fiat, Peugeot or Citroen it is even easier. Just connect a 12v battery to the jump start connections under the bonnet, then you can change the battery over without loosing feed to radio.
Geoff
Many of the radio codes are 0000 or 1111 or 1234 by default.
So unless you have changed it, it may still apply
Geoff
thanks a lot
Geoff
On our Rapido the radio / head unit is connected to the Habitation Batteries. Guess how I found out :unsure:.
And the code is ****** (y)
