Lookingfor a cassettec200 cs??
If you're just looking for the cassette will the fresh up sets not fit?
Broken Link Removed
Pete
They only make the wheeled version now, fits fine. Beware the vent fitting may also need changing.
Always worth checking Facebook marketplace
Is it longer than original? Or just doesn’t slide all the way home? If doesn’t slide home. Check yellow knob is rotated in correct position.
Hi Sue. That will do the trick. The fresh up kit you have is a direct replacement and will fit perfectly. Swap the vents and it will fit.
Then buy another vent so you will have a spare cassette.
Thank you so much for your help.... much appreciated
There is one on bids if you are desperate
Or this one
Reactions: f6c
We have both the version without wheels and the newer one with wheels . They both fit perfectly.
What Motorhome do you own ? They should both fit .
My son replaced the cassette in his 2009 Pilote and it was totally different to my Thetford.
Where did you get the reference number from ?
Gave a copy of the plate in the housing to the supplier
The only other thing I can think of is the vent. Does it look like this ? If so it might need turned by 180 degrees.
No the old cassette is wrking perfectly. Just wanted the new one with wheels!
Hi Sue
We did the same as you and brought a wheeled version of the C200 and it fitted perfectly in our Bessacarr 2006. If your anywhere near Hertfordshire I’m happy to help or let you try mine?
Darren
