zac
My Rapido has had a very small water leak in the back garage which up until now has eluded me, this morning i took another look and found where it is leaking. It's this 90 degree pipe on the right that is leaking from the join. What are these called and anybody know where i can order one from? This is basically the freshwater drain but water sits in this all the time up to the tap which then blocks it off until needed to drain. The replacement option is just in case the repair does not work with pipe sealant.
Motorhome is a Rapido 10000DFH
Thanks in advance
Thanks in advance
