In the past few days I have been on a steep learning curve as I investigate the new kit needed for a planned Roamer seatbase 230Ah install. When chatting with Roamer they recommend charging between 30% and 80% of capacity and then isolating from loads and chargers completely when not using the MH for longer periods. I plan on upgrading my Schaudt solar regulator to a Votronic 1715 Solar-Regulator MPP 250 Duo Dig since this has a specific LiFePO main charge setting at 14.2v and will connect via the EBL using the same cable set which I used for the Schaudt. This regulator also trickle charges the starter battery which is great in the winter months.
Can someone recommend the best way to isolate the leisure lithium battery from the solar regulator (to avoid charging the battery over 80%) whilst still being able to trickle charge the starter battery? For example, is there a fuse on the EBL or Solar regulator that I can remove?
