Mine's useless, so I need a replacement.
When I get it out and try to unfurl it, it just wants to coil back up again. This means it won't straighten properly so any waste water I pass through it gets sort of stuck in the kinks and bends. Short of doing the syphon method it means I spill it where I don't want to when I disconnect it (and sometimes I can't get rid of everything).
So my question - what kind of pipes do you guys use for running your grey waste from underneath your MH to a ground level drain hole? Is there a technique for using the sort of corrogated grey ones (that come up for every search) that I need to know?
edit - I just found this thread which I didn't on first searching which is interesting.
