Location of Truma fan in N&B Arto 69GL (2003) (1 Viewer)
CAB96
1,323
2,567
Stockport, UK
T6 Leisuredrive
Presumably it will be in the Truma unit?
It may be helpful to say what model the unit is.
N
Oct 12, 2009
11,500
25,474
A Class N+B Arto 69GL
Since 2009
Depending on the model you have, this may help ?
I could not find the model number on the label attached to the boiler, but I have now found it on the 'boiler room' door.
It is C-3402/ C6002, as Figaro posted, so thanks. I presume the fan is the upper unit on the right-side of the boiler in the first photo in Figaro's post.
I am not sure if I have a problem yet - just a strange noise on start-up on one occasion but not recurred.
I just wanted to know where it is in case.
Thanks.
Geoff
Feb 22, 2011
10,513
22,055
Newcastle under Lyme
Hymer B544 A Class
Since 2015
I think mine is the C6002, it works faultlessly at 20 years old and it's never had anything done to it in the 9 years I've had the Hymer.
I've often thought I ought to clean out the air intake fan as I assume there will be a filter on it ?
But unfortunately I've always found something better to do as it seems like a bit of a faff to get too in the bottom of the wardrobe.
N
Oct 12, 2009
11,500
25,474
Since 2009
Same in 15 years on our 21 year-old N&B. Long may it continue.
