Hi all,
Just starting Phase 1 of my Lithium upgrade in my Elddis Autoquest.
I'm looking at Fogstar Drifts, 2 x 105Ah in parallel, due to ease of fitting.
Existing MPPT and Lippert (Shaudt) Controllers are both switchable to Lithium.
My only other change at this point will be the 230v charger. I'm looking at disconnecting the 230v plug from existing slide out PDU charger, and using the feed for a Victron IP22 20AMP charger with a 'Kettle' type plug replacing the 3 pin.
Can anyone advise if this all sounds OK please? Do you recommend adding a smart shunt, or will the Fogstar bluetooth connection enough to keep a check on battery state?
