I’m looking for a drop in lithium replacement for the existing battery in my Bailey Adamo 69-4. Does anyone have experience of doing similar and finding a battery that fits in the existing tray in the floor of the Adamos?
Thanks, yes on measuring so far the only one I can see fitting straight in the box is an ecotree one. I’ll dig into the other bits a bit more. The truma solar controller definitely has a lithium option.I couldn't find anything of any use to fit the box in my Autograph so gave up and fitted 2 x 300Ah Fogstar's under the seat next to the bathroom, leaving the box free for storage of bits & bobs. The problem you'll have is the height of the box, which is actually quite shallow as the original Banner batteries are only 190mm high, but even the 100Ah Fogstar is 209mm so it may be tight but worth checking first as you may not be able to put the lid on.
I assume you've looked at the other bits you'll possibly need to do regarding charging as your BCA charger won't have a lithium profile.
If you havent ought them yet, Fogstar 280 definitely fits under the drivers seat and it depends what you have under your passenger seat already to fit another one and they are nearly £500 each cheaper than what you are buying. (unless that is a fitted price)![]()
12V 280AH SEATBASE LITHIUM BATTERY
12v 280ah Seatbase lithium battery the UK's most powerful Seat base battery. Packed with advanced safety features PRE-ORDER NOWwww.lithiumpro.co.uk
wow, that's expensive. That's not what ppl are paying for batteries is it? Should take a peek at the Fogstars, id guess everyone is using the same cells...![]()
