Lithium low charge rate on alternator/B2B
Mar 3, 2010
48
79
Southwell, Notts
Rapido
I've searched for a while but not found answer, so one of the pros on here will probably be much quicker.
Rapido Fiat Ducato 2011, traditional alternator, Victron 12:12:30 B2B, Fogstar Drift 230Ah. But only charges at about 12A when driving, even when e.g. 50 or 60 %SOC. B2B is set to Li and trad alternator. Are there any other settings I can tweak, or is this normal?
Was the original split charge system disconnected when the B2B was fitted? It should have been, otherwise it creates a loop that stops the B2B working at full capacity. This does sometimes get overlooked.
As others have said, your fridge is consuming around half the output.
Ian
Thanks, guys, you're right. I've been static on hookup in Spain for a few days, so not had a chance to test it. Yes, the current to Li battery drops when engine running and fridge is turned to battery. I'm slightly surprised, as I have the extra NC relay to to open and disable the split charging that the internal relay in the control panel would originally have connected both batteries when engine is on. And I thought that the fridge supply was on the alternator/cab battery side of that - unless maybe that is 'starving' the supply from alternator into the Victron B2B.
Obviously, a bit more research needed.
