The collective wisdom is much needed.....
My van has been parked up since since middle of December and the batteries were being managed at 80% charge via the setting on the voltronic main charger (e.g it has a charging program which automatically maintains a charging state of 50-80 % of the LiFePO4 battery, when the vehicle is stopped. This charging state also simultaneously supplies the 12 V consumer loads and systems, such as alarm systems, WLAN etc., as well as the vehicle's starter battery and the consumer loads in idle mode).
I have also removed the fuse from the votronic solar charger, so i thought that the batteries should not get a charge unless the battery SOC falls to<50% and the battery temp. was >0C. However during the recent cold weather i noticed that the BMV was reporting the batteries were charged at 100%, so I switched off the main charger and have brought the SOC on the BMV down to 80%, however the BMV is also now reporting the voltage is only 12.51v which according to the table below means the batteries are at 14% SOC not 80%!!?.
My setup is.....
330ah (3x110ah Ecotree lithium's)
votronic solar charger via the [Broken Link Removed] 29
50amp votronic mains charger wired direct to the batteries
victron 30amp B2B
victron BMV712
I would really appreciate your thoughts on why the BMV would reporting only 12.5v's at 80% SOC
My setup is.....
victron 30amp B2B
victron BMV712
