No.
Lifepo4 are considered very safe from thermal runway and fire
Had mine two years now and no I don’t box it inDo you protect a Lithium iron Phosphate battery either in a box or fire proof container, because mine will be under passenger seat ?
E bike batteries will be NMC chemistry or similar, which can burn very energetically if something goes wrong.I keep my genuine Bosch e bike batteries in a fire proof container when they travel in the motorhome . Just being careful . No evidence based research to back my decision , i just do .
I build home batteries and the box out of plywood, same type of cells as in motor home use, Lifepo4. I do add extra protection past the bms as in T class fuse or a DC breaker capable of braking the ark without exposing the ark to the air, as in ignition proof.Do you protect a Lithium iron Phosphate battery either in a box or fire proof container, because mine will be under passenger seat ?
LiFePO4 doesn’t burn.With the temperature those things byrn at,
No, but limited thermal failure and venting is still possible.LiFePO4 doesn’t burn.
Other lithium chemistries do but not LiFePO4.
Ian
Overall, it's probably safer than a wet lead acid.No, but limited thermal failure and venting is still possible.
How dangerous and or the possibility is that, as it's under the passenger's seat ?No, but limited thermal failure and venting is still possible.
I would rather have a LiFePO4 battery under my seat than the lead acid ones put there as standard. There really is no need to do anything special. These lithium leisure batteries have an entirely different chemistry to the ones used in e-bikes, e-scooters and most cars. Li is not the cause of the problem in these other batteries, it is the other chemicals they use instead of FePO4.How dangerous and or the possibility is that, as it's under the passenger's seat ?
As long as it is a reputable supplier and manufacturer, and hasn't been mechanically damaged, or incorrectly charged, the chances of failure are very low. Quite probably far lower than lead acid, as others have said.How dangerous and or the possibility is that, as it's under the passenger's seat ?
