Cheers tinker2
Pod Light Kit WHITE Daytime Running Lights DRL LED - Ducato, Boxer, Relay, X250 LP-X250W
Hi AndyDid you have any luck and do you need to cut the hole out to fit?
Check out the link higher up by fontie they do up to 20212021
Mine were bought with the advise of, Two on Tour.Hi Andy
Haven't bought yet but got good links of footie and tinkers. They look like straight swap with 2 screws £130
Do you have a link to what twotour advisedMine were bought with the advise of, Two on Tour.
Ages since I had to remove one of the light fittings on the back of our AT but, from memory, I used a plastic panel tool inserted between the lens cover and the back and gently pried off. Think Dane Diabalo might have more info?Any idea how the rear light cluster is attached, one reverse light has gone.i assume the pop off but I don't want to damage the fitting
If they are the round lights some twist about 20 degrees and then pull out. Sometimes you need to get creative with a rag for extra grip without causing damageAny idea how the rear light cluster is attached, one reverse light has gone.i assume the pop off but I don't want to damage the fitting
Brilliant ill get the wife on itIf they are the round lights some twist about 20 degrees and then pull out. Sometimes you need to get creative with a rag for extra grip without causing damage
No slot, it's a newer lense but thanks for lookingPicture in this link, the slot may be on the bottom or top, I spent ages working on the bottom only to find they had ben put in upside down.
Auto trail rear lights
Hi all looking for a bit of help? I have a auto trail 2012 Comanche and one of the rear light bulbs have gone but cannot see how to change it. Any answers would be appreciated we are in Holland all week so no access to are dealer.www.motorhomefun.co.uk
