Is it just the lights that are not working, ie do the pump and 12V sockets work? Does the electric step work?
I think the Burstner has an Elektroblock, which is a central 12V controller and distributor, which contains a mains charger and a whole stack of fuses. It also has a battery on/off switch, which might need to be switched off and on to reset everything if a new leisure battery has just been fitted.
Does your Burstner have the little remote display unit above the hab door ? These can be a bit sensitive when you scroll through the functions and you may have disabled the lighting option or clicked onto and activated one of the timer menus for the lights ?
