Light Problem
Denis67
Burstner Nexxo
I have had a bot of an epic with my living area lights. Took out the old rail lights and fitted led strip lights on the 12v system. They were all working before putting everything back together and I believe I may have shorted the light circuit, replaced the fuse, however, I now have no power to the lights and other systems that work off the lighting circuit. I have checked all the fuses and everything else is working - any suggestions??
Hi and welcome.
You need to do some basic testing with a multimeter starting at the fuse box.
It sounds like you have tripped or blown some other related connection on fuse.
Example, my lights have a main fuse but have also a specific control unit aside from the fuse in the main electro bloc.
