The Artilleryman
Visiting Coventry
Checked my KS Energy hab battery and it's showing 11.71v 82% SOC, doesn't seam right to me.
Voltage across the terminals is the same.I wouldn’t be worried about the SoC reading (they tend to be go awry) but the 11.71V reading looks concerning.
I’d be inclined to get that on charge soonest.
Are you able to measure the voltage at the terminals. That’ll help identify if it’s a battery, or a BMS, issue.
Ian
That’s ok, slow charge even better coming from low SOC. At 11.71v it’s about 2.92v per cell. Bellow 3v, it’s not much energy left, less than 5%. But , it’s still safe up to 10v when bms will disconnect. Better not to get there, and you are doing ok to charge it up.Yes, it's on charge, but only from the standard in built charger.
have you checked what its putting in? There must be a reason its run flat, or has it been left a long time ?Yes, it's on charge, but only from the standard in built charger.
5.5 a on a flat battery, theres something wrong with that. Is it set correctly?Getting 5.5a charge from onboard charger. I've got a Victron IP22 12/15 waiting to be fitted, problem being the battery terminals are round post brass, rather than the preferred bolt type and cannot make up anything to easily connect it the battery - no crock clips or eyelet heavy enough - and I'm unable to drive at the moment so can't get anything from screwfix etc. tomorrow.
Fitted new end of November charged to 90% SOC then discharged to 81% (internal lights), then electrics shut down and 12v batt. fuse pulled on BCA PDU, so should not be discharging. Checked every couple of weeks via app. then health problems and cold weather stopped me checking - need to be next to MH for BT to work.have you checked what its putting in? There must be a reason its run flat, or has it been left a long time ?
No settings available, it's a BCA dual output unit hab 12v + hab battery charger.5.5 a on a flat battery, theres something wrong with that. Is it set correctly?
Whats temp where the battery is? I keep forgetting hiw cold it is back in UKNo settings available, it's a BCA dual output unit hab 12v + hab battery charger.
That makes little sense. It could suggest there is a fault somewhere.My lithiums always cock up the smart shunt when they get cold.
They were reading 100% yesterday on about the same voltage. They are about 50% as I checked them before it went cold.
Fair enough. the batteries BMS should provide protection, but that is another precaution that can be taken. EXCEPT ... if the batteries have heaters, the chargers should be left on, otherwise they will never come on and warm the batteryI would warm it up if you haven’t already and don’t charge it in freezing conditions whatever you do.
This should not be the case. it is either a faulty or a rubbish (same thing) BMS.The voltage and SOC readings are always really out when they are cold, I think it’s the BMS somehow.
You can't really rely on the BMS SOC when brand new until you have done a FULL charge so you are on a known charge position. By charging to only 90% as reported by the BMS you cannot actually be confident that is the true State of Charge. And with Lithium, above around 20% or so SOC, it is very hard to tell the level of charge looking at voltage as the discharge voltage curve is so level.Fitted new end of November charged to 90% SOC then discharged to 81% (internal lights), then electrics shut down and 12v batt. fuse pulled on BCA PDU, so should not be discharging. Checked every couple of weeks via app. then health problems and cold weather stopped me checking - need to be next to MH for BT to work.
I wonder if during the 2 very cold spells we had weather this turned a heater of some sort on, only thing I can think of.
The bluetooth bit is a method of communication, not a method of calculation. The first is allowing the presentation of the second, and nothing else.I have KS battery's and I like to think I was a pioneer in them in that I was one of the first to fit them before blue tooth etc was fitted
My 2x120 ah have a small window on top which shows temp and soc (I think) but the battery's are buried in cupboard so I can't see them and therefore never look at them.
I rely totally on a votronic smart shunt which has never (in 5 yrs) let me down. I always know my battery voltage and SOC. It calculates input against output very efficiently to lets me know where I stand
I believe (flak jacket and hard hat fully in place) that leisure vehicle users put too much reliance and faith in so called blue tooth technologie.
One has a battery at 100%charge.. how do we know.. because we have just charged it . And we know size of battery so we know how much amps/kwatts said battery holds.we then proceed to discharge battery.. x amps.??
At same time solar is inputting amps into battery .. no problem
My votronic is clever enough to work out.. 5amp discharge plus 7amp charge =2amp charge.. which shows on the display.
Oki doki...I had to read that 3 or 4 times and I believe you are indeed agreeing with me ,(however probably wrong) .The bluetooth bit is a method of communication, not a method of calculation. The first is allowing the presentation of the second, and nothing else.
You are not using bluetooth for find the battery information because you are looking at a wired display. it doesn't make it any more accurate by doing so.
I can do the same as you for my batteries by looking at the wired display on my Victron BMV. I can also see the same information by connecting to the monitor via a Smart App on the phone. makes it easier to use but has no impact on the data.
sorry, no, I am notOki doki...I had to read that 3 or 4 times and I believe you are indeed agreeing with me ,(however probably wrong) .
why do YOU need bluetooth? You don't. But if the device that is performing the calculations has no display and relies a Smart App and relays that information via Bluetooth, then that is when Bluetooth would usually be needed.So are you saying blue tooth is only displaying (through Internet connections) what the battery is telling the votronic display direct thru the fitted smart shunt.
My battery's.. Once fully charged will show me.. via Votronic Smartshunt Computor Display at all times voltage and SOC.
So why do I need bluetooth??
I think Hoovie has made a good point about the accuracy of shunts but the question for me is wh your charger is only putting such a low charge in? It should be maxing.Thanks for the comments and help, my main concern is What caused the battery to discharge down to a level where the bms shut the battery down.
The battery is still on charge at 5a from the onboard charger, so should be fully charged by lunch time - will check battery voltage is 14.1v or there about. Will then physically disconnect the battery and monitor via BT and multi meter.
I'm well aware of the charge/discharge characteristics of non LA batteries as I started model car racing with 1200 mah SC ran right through to 3600mah NiMH. We abused these as we wanted the absolute max. charge and they would then be fully discharged in 300 seconds.
Very simple, cold activated the heater pads and drained the battery without having a charger connected. The shunt can’t see the heater pads to register a draw to account for, because it’s before the shunt on the battery side. If the heater pads would been after the shunt, like any other load, your shunt would of told you that your battery is going down.Thanks for the comments and help, my main concern is What caused the battery to discharge down to a level where the bms shut the battery down.
Because that’s the size of the charger,I think Hoovie has made a good point about the accuracy of shunts but the question for me is wh your charger is only putting such a low charge in? It should be maxing.
Thats a very low power, presumably cheap - another manufacturer run by accountants?Because that’s the size of the charger,
If you are referring to lithium batteries with integral heaters, it would be a very strange (read poor) design to have the heaters to be powered by the battery and activate at low temp. That would be very wasteful of battery power as there is no need to heat the battery to above freezing if there is no charging available.Very simple, cold activated the heater pads and drained the battery without having a charger connected. The shunt can’t see the heater pads to register a draw to account for, because it’s before the shunt on the battery side. If the heater pads would been after the shunt, like any other load, your shunt would of told you that your battery is going down.
Moral, if you have heaters, leave charger on, without restricting charge on cold.
Point about the onboard charger ... Is it really a 5A charger you have and is this really a primary charger for the batteries when hooked up?Thanks for the comments and help, my main concern is What caused the battery to discharge down to a level where the bms shut the battery down.
