Leveling Ramps
Manchester, UK
Burstner t700
Early 2019
Having spent 5days in Brittany and now in Spain, noticed a lot of French MH owners reverse up there ramps as I drive up mine, can't see the difference, is there any?? Might be a daft question but would like opinions.
I have a feeling that the obligatory safety paperwork that came with mine had a big red cross through a picture of a van reversing up them!
No idea why, I've done it both ways.
With the ComfortMatic when I am travelling solo I find it easier to reverse onto the levelling ramps. Going forward seems harder to get it right, for some strange reason.
I drive up my ramps due to mud flaps front and rear, reverse once and caught the rear mud flap. So alway drive up now, and use a chock to stop any movement if needed
Funnily enough I asked the same question under “Mounting Ramps” last Monday and got a few very similar replies.
Buttttt… the other question is if you drive up the ramps are they better on the front wheels or the rear ones ?
Reverse is usually lower ratio than 1st so easier on clutch
Isn't it the other way round? 1st is a lower ratio than reverse, TTBOMK. But if you're happy reversing up 🤷‍♂️
Mike.
It depends on the ground incline, and grip. My van has a lower bias on the front axle, so I try to exploit that wherever possible. On some sites there quite regimental [ mental] and you have to park facing outwards, this is generally to aid extraction in an emergency, or breakdown as just about every van will have a towing point on the front.
Mike.
Reduction ratios 1st 3.727:1; 2nd 1.952:1; 3rd 1.290:1; 4th 0.875:1; 5th 0.647:1; REVERSE 3.154:1; Final drive ratio 4.933:1 (74/15)
For a manual x250…
With a Comformatic it s better to drive forward onto ramps as said 1st is lower than reverse very easy to do in a clutch reversing onto ramps with a Comformatic.
