Lenny's Heading South, not a Clue Where. (83 Viewers)
Jan 28, 2014
22
20
Hymer B MC T580
Since 2008
But in another thread you said you stopped the charging didn't you?
I only charge with the Schaudt WA121545 and use the fridge on 12v when 'mobile'.
When not 'mobile' I use a 30a Victron charge set to Fogstar recommended setting. In two years I have never had more than 280, that's what I paid for - that's what I get.
What would be an acceptable number of COVs when charging mobile or not?
MichaelT
4,049
8,545
Colchester
Carthago I 143 LE
Since 2016
But your achaudt is set to lead i think so not getting correct charge but not an issue as you say you've got what you paid for.😀
Jan 28, 2014
22
20
Hymer B MC T580
Since 2008
You mean my 'Schaudt ' Any other setting gives to many COVs.
While Mobile! With the Fridge on!
Jan 28, 2014
22
20
Hymer B MC T580
Since 2008
Shaudt does fridge both do batteries.
As I mentioned my fridge 12v is powered directly from the battery terminal therefore the booster never sees the trickle charge switch over amperage of 2.5 amps and continues to give 14.4 volts.
Sorry LennyHB for this diversion.
WESTY66
6,878
18,101
South Yorkshire
Carthago Chic C-Line
All the gear, and no idea!
Jesus nearly had a heart attack just found out how much it is to go in the mosque.
€33 each😭😭😭
You could both convert to Islam and you can go every Friday, several times a day👍👍
East is over there➡️➡️
