Love the cooker top with legs
Can I ask what size of battery(ies) you have?Only used 9%.
2 x 230ah Fogstar they are charging to 485ah.Can I ask what size of battery(ies) you have?
This is why I struggle to understand Lithium, how can it be 25ah over the combined capacity of the two batteries?2 x 230ah Fogstar they are charging to 485ah.
Mine is a 300 but charges to 306This is why I struggle to understand Lithium, how can it be 25ah over the combined capacity of the two batteries?
We are having 290ah fitted so I guess we will get a little more than that, I hadnāt realised.Mine is a 300 but charges to 306
Our 280 goes to 305 and the 200 goes to 205Must a lithium thing. We are
Where do you look to see the total??Our 280 goes to 305 and the 200 goes to 205
On the Bluetooth app for BMS.Where do you look to see the total??
Sorry Michael I forgot to let you know the rafter was delivered safely, thanks
I'm lucky if I get 280 from my 280Our 280 goes to 305 and the 200 goes to 205
But in another thread you said you stopped the charging didn't you?I'm lucky if I get 280 from my 280
I only charge with the Schaudt WA121545 and use the fridge on 12v when 'mobile'.But in another thread you said you stopped the charging didn't you?
But your achaudt is set to lead i think so not getting correct charge but not an issue as you say you've got what you paid for.I only charge with the Schaudt WA121545 and use the fridge on 12v when 'mobile'.
When not 'mobile' I use a 30a Victron charge set to Fogstar recommended setting. In two years I have never had more than 280, that's what I paid for - that's what I get.
What would be an acceptable number of COVs when charging mobile or not?
Wawell mine seems to work OK with my victron b2b.You mean my 'Schaudt ' Any other setting gives to many COVs.
While Mobile! With the Fridge on!
But that's not a Schaudt is it.Wawell mine seems to work OK with my victron b2b.
I have bothBut that's not a Schaudt is it.
Which one runs the fridge and which one charges the battery?I have both
Shaudt does fridge both do batteries.Which one runs the fridge and which one charges the battery?
Wow, I didn't mean to hijack the thread, just wanted an explanation.Shaudt does fridge both do batteries.
As I mentioned my fridge 12v is powered directly from the battery terminal therefore the booster never sees the trickle charge switch over amperage of 2.5 amps and continues to give 14.4 volts.Shaudt does fridge both do batteries.
