Leisure power failure
Manchester
Auto Trail Mohican
18 years
My vehicle battery failed on me. I'd had an operation so it sat on my drive for 8 weeks. I eventually changed the battery and now the leisure side of the vehicle isn't working. The step works and the fridge light is on, but the control panel is barely lit and there is no response from the control buttons. I've checked all the fuses and everything seems ok. Can someone tell me if this is a control failure issue or could there be something I'm missing.
As above check L B voltage.
Presume u have split charge or b2b ? If so does leisure side come to life with engine running?
did you charge your leisure battery AND how? if you only charged the vehicle battery (or didnt charge it because it was new), then the leisure battery may also need charging, though with 18 years of experience i am pretty sure you know that already. i would try and charge your leisure battery separate, just to make sure the issue isnt with your on board charger before having to buy a new leisure battery and then going through the 'should i fit lithium' debate in your head !!
