leisure battery replacement
birmingham
kon-tiki 669. mazda bongo
since2011
HI, I have to change two leisure batteries Do I have to disable the solar unit first or just change the batteries.
Thanks in advance
John
Disconnect the solar from your controller then connect the batteries first so your controller can see what batteries they are then connect the solar…😎
You have replies in your duplicate post here:
bit late now as i have just replaced two batteries - but how do you disconnect a solar panel from the controller - what controller - where ? how and why ? and where do i find it ?
What set up do you have
Two wet cell batteries in a sprinter winchcombe MH with Sargent control and ff 80w solar panel
I have battery charge meter on the sargent panel that said the duff batteries were charged 100% but didn't hold charge but now I have the new ones in it says 20% even though the solar panel has been putting a lttle bit and I have connected to ehu for a couple of days and sits at 12.6v
The solar panels has to be connected last so the controller can take a reading of the batteries
