Frm2005
- Apr 6, 2025
- 5
- 0
- Caddy
Hi all, bit of a head scratcher here, hoping for some advice on this. Here’s my set up, I’ve got a VW caddy maxi van I have a leisure battery powering a 3000w pure sine wave inverter. I have a 25mm² cable coming for the live terminal of my vans battery through a split charge unit which switches on when the vans running, charging the leisure battery in the back. The negative is bolted to the frame of the van. However, when I try and use my microwave it drops voltage on the screen of the inverter alarms and shuts off. It does work a bit better if the vans running linking both the main battery and leisure battery, but it’s very temperamental. It worked perfectly in my old van however, this vans a little longer, could volt drop be an issue? I’ve tried putting two leisure batteries in parallel too, this hasn’t resolved the issue. It’s a cheap 800w microwave I’m using, not sure if I need to try and use a lower wattage unit see if that helps, or move the inverter and battery closer to the main battery of the van. What’s your thoughts? Any advice is much appreciat
ed.
ed.
