We have a new Adria supreme motorhomeOur leisure batteries deplete while we drive what is causing this
Welcome to the forum, a bit more details would help as it could be a multitude of thingsWe have a new Adria supreme motorhomeOur leisure batteries deplete while we drive what is causing this
Thank you we have a B2B charger and it’s switched on. When the vans on hook up they charge but when we drive the battery drops. 100 miles of driving our leisure battery went from 100% dropping to 75%.You need to see if there is a B2B charger fitted, this would then charge your leisure battery via the alternator as you travel. It may be switched off or none fitted.
Some questions. Was the B2B a factory installation or added later? What type of leisure battery have you got e.g. gel or lithium? What age is the van, how long have you had it and has it always lost charge or is this a new thing. Is your fridge a compressor fridge or a 3 way one that can run on gas?Thank you we have a B2B charger and it’s switched on. When the vans on hook up they charge but when we drive the battery drops. 100 miles of driving our leisure battery went from 100% dropping to 75%.
That's roughly 2 hours. If your battery is a standard 100Ah, that roughly tallies with a 25Ah draw, which is approximately what you'd expect from the fridge and no charge.Thank you we have a B2B charger and it’s switched on. When the vans on hook up they charge but when we drive the battery drops. 100 miles of driving our leisure battery went from 100% dropping to 75%.
Thanks no fridge on we drove 100 miles batteries dropped from 100 to 75%.could be fridge on and not charging ? you need to give a bit more info
There is nothing running at all when we travel the leisure battery is 200ah lithium it’s as if when we travel the power discharges when it shouldn’tThat's roughly 2 hours. If your battery is a standard 100Ah, that roughly tallies with a 25Ah draw, which is approximately what you'd expect from the fridge and no charge.
It’s a brand new Adria with lithium it’s the first time on a trip so only noticed as we have a victron app that showed the battery dropping charge as we drove. We have a 3 way fridgeSome questions. Was the B2B a factory installation or added later? What type of leisure battery have you got e.g. gel or lithium? What age is the van, how long have you had it and has it always lost charge or is this a new thing. Is your fridge a compressor fridge or a 3 way one that can run on gas?
Factory fitted b2bIt’s a brand new Adria with lithium it’s the first time on a trip so only noticed as we have a victron app that showed the battery dropping charge as we drove. We have a 3 way fridge
I agree with.It’s a brand new Adria with lithium it’s the first time on a trip so only noticed as we have a victron app that showed the battery dropping charge as we drove. We have a 3 way fridge
Could be worth checking the fuses mentioned in the other post since it cured the problem in that case. However you probably best avoid any radical intervention so that you don’t compromise the warranty.Under Warranty Back to the dealer.
If it was not factory fitted I would say there might be a loop back through a redundant split charge relay. The higher voltage Li leisure battery would then be charging the lower voltage engine battery that the ECU was trying to keep at 12.3 volts. In other words the leisure battery would be powering everything and the alternator would have been switched off. I would believe a dealer capable of making such an elementary mistake but not Adria.So where has 50Ah gone if nothing is switched on?
What is the victron app exactly? Presumably you have a Victron device somewhere. Is it maybe a solar controller, or is it a shunt battery monitor? Could you post some photos of the electrics if you're not sure what's what? Are you OK with using a multimeter to take voltage readings of the battery voltages?we have a victron app that showed the battery dropping charge as we drove
