A 'buck' converter outputs a lower voltage than the input voltage, that's why it's called a buck or stepdown converter. In the small print you will probably find that the input voltage needs to be at least 1V higher than the output voltage. So if you want 12.0V you will need an input of 13.0V minimum. Not a problem if you have EHU or solar, the battery will be at 13.4V at least, but may be a problem if not on EHU and no solar. You usually want LED lights when it's dark, so there is no solar.A cheap 12v buck converter inline will smooth the voltage to a consistent 12v and probably resolve the issues.
Would something like this do the job? How many amps do led strip lights draw? I'm thinking of converting my fluorescents.Better to get a 'voltage stabiliser' which takes whatever input voltage is available (eg 10 to 15V) and outputs a steady 12.0V. Also called a 'buck-boost converter'.
Looks OK to me, maybe a bit over the top, a 5A output would probably be sufficient, but that would still work fine. LEDs are generally much more efficient than incandescent light bulbs or fluorescents, so 5W of LEDs would give out the same or more light than a 20W fluorescent, and 5W is only about half an amp at 12V.Would something like this do the job? How many amps do led strip lights draw? I'm thinking of converting my fluorescents.
Nowadays there are several different types of LED strips, with different light output per metre (more or less LEDs per metre). And that's before you consider colour temperature (warm white, cold white etc), and remote controls that change the colour. Some even allow programming of individual LEDs along the strip to produce all kinds of effects, if you like that kind if thing. There's a basic intro here
Everything You Need to Know About LED Strip Lights | Waveform Lighting
www.waveformlighting.com
