Does anyone know if bulbs in these lights can be replaced and if so how to remove the bulb. Everything I can find online is the complete unit and with the lugs on it I’m not sure how I would get the whole unit out.
Try a blunt blade (flat screwdriver etc) in the slot and carefully levering.
You may find the bulb is a flat disc circuit board with 6 LEDs.
Easily replaced.
If it's a solid unit with just 2 wires it will be a full unit
