Lawler999
- Nov 18, 2023
- 3
- 5
- Autocruise starspiri
Had a leaking window on autocruise starspirit , only noticed when I pulled the seat cushions away from the walls , the wood the seat cushion sits on was wet and showed signs of water sitting on it . So I removed the window and was surprised there was only a bit of clear silicone and the thin black fasket on the window ( I thought it would have been more substantial) I decided to put a large bead of sealer just inside and proud of the black gasket to try and make a better seal , only took about an hour to do .I also noticed the plywood wall was black and wet in places , will this dry out in time ?
Looking at the wall under the window you wouldn't have know it had leaked the wall covering looks OK, no bubbling . Just concerned about how long it will take to dry out , time to get a damp meter I think .
