Leak at joint going into pump.
Swift Bolero EK600
Getting there owner since 2021
So I filled up, ran the taps to get rid of any air and fired up the boiler to make sure heating was working. All spot on until I noticed the pump was kicking in every few seconds. Checked to find a pretty big puddle of water and the joint leaking in a very awkward place (obviously) I'm not sure how to dismantle this to check or maybe even order another part if required. It's leaking right at this blue coloured part at the right hand side, bottom of the pump. I don't know what it is or want to force anything. Can anyone help?
While waiting for others who can help, could you get a better in focus photo of the leaking bit and also pull back a bit for another photo showing the pipes leading up to the pump.
If difficult to get phone in and take photo, set your photo app to 10 seconds timer and then hold it down there steady.
It may be just fittings that need pushing together.
Tried pushing them together with no joy. I'll try and get a better pic but it's tight against the boiler
Looks like it’s a Flojet pump Pull bottom pipe off -try cleaning then push back together
Also looks like it’s fastened to the wall with 2 screws. Will be simple to remove and replace
Ditched it and went to stay in a friends static over the weekend. Thanks for the replies everyone, I'll take the pump off to clean and check the seals.
