Time to share my problem.
For a couple of years I have been trying to fix this pesky leak. Basically I get a wet stain emanating from one corner of the roof light, towards the front drivers side where there's a natural slope.
I have tried everything including removing the Heki, treating what might have been micro cracks around the edge with Captain Tollys, sealing what might have been micro cracks in the nearby roof with gelcoat, then refitting with fresh sealant (Puraflex 40 as recommended). Still leaks.
Most recently I tried replacing all the rubber seals and adding a new fillet of seals all around the edge. Still leaks
Prior to my own efforts I paid someone over £700 who promised to fix it. He did a neat job of resealing the join between the cab and the hab sections but he went AWOL when I reported it didn't stop the leak.
I have been up on that roof countless times (on a ladder not literally standing up there). I am at a loss as to the issue or how to solve it since I cannot work out where the water is getting through.
I have found it helps to park with the rear a bit higher. I also have observed that the roof looks like it is marginally concave along that area, suggesting that the roof and/or the underside of the roof may have warped a little over time (It was built in 2007). It's possible that might lead to a slight puddling when it rains, which could then be seeping through?
If the latest theory is correct then the roof needs some more serious engineering to rectify the dip.
But of course it might not be that and doesn't explain where the water is getting in because the Heki (appears) to be watertight and the puddling isn't that deep anyway.
The roof timbers look to be still good, I make sure any ingress is allowed to dry and use a dehumidifier sometimes.
I promise you all I have spent many many hours looking and exploring where the water might get through, all to no avail.
So now I am consider one or both of the following:-
-Find a bodywork specialist (marine maybe?) who can strip off the outer roof and rebuild as new?
-Replace the Heki with a brand new one?
Has anyone else had a similar problem? Has anyone advice on how to find and commission the bodywork specialist?
If I replaced the Heki I can't seem to find one that has a crank to open and shut, they all now seem to just have a bar that you lever up and down. And of course experience to date is all that expence and trouble could still leave us with a damp ceiling.
