OK - I've asked this question before but now going to have a bit more maths. I promise I won't ask again as next time hopefully I'll have Lithium!! Also the Renogy 2000w inverter is slightly reduced now on Amazon
So I have 2x90Ahr Lead Acid batteries with a Sterling 60A B2B(Overkill I know but solar means it's rarely doing much).
Almost everything I do is 12V and low wattage except for wanting to make porridge for the missus hence the question
I've measured the 800W microwave at 1280W when in use. Therefore I am going to be drawing at least 106A when in use and likely a bit more due to inverter inefficiency. However I only need to run the microwave for 2 mins a day. That's 3.5Ahr so overall very little but at an enormous current.
Using the C5 rule my batteries are only good for 36A which leaves a shortfall of 70A. My 60A B2B should supply about 50A??????
So will it work and if so is it very bad or just a little bit bad to start the van, leave it run for 2mins for the Sterling to kick in and then run the microwave for 2 mins. More worried about the batteries than the van as I would be tending to move most days when holidaying.
