I have a 2018 IH FIAT, and for some reason it has been changed to km instead of mph on readout (where you look to see how many miles it has done) I have tried and can’t find where or how you do it in the menu. Can anyone help
Divide by 8 and times 5.
We have to do that to reset the clock - it’s nuts!Had to put old radio in to alter menu then put new one back in !!!!
Or multiply / divide by 1.6 depending on which way you want to convert.One of the easiest conversions to do.
Anyway 50kph = 30mph and 80kph = 50mph ish
That covers many speed limits.
No’ it’s not illegal to drive in kph. It’s a legal requirement to have a display in both kph and mph.Remember it is illegal to drive here in Kph. As my Fiat Ducato is not the clearest to read, I have a “heads up display” in mph and kph. Therefore use the mph here and when abroad use the kph setting. I would speak to IH or Fiat for the answer.
Not an expert but it shouldn’t as its mph in the U.K. so not correct.Will it pass an MOT if only in kph.
My van has had its mot recorded every year in km for 5 years.Not an expert but it shouldn’t as its mph in the U.K. so not correct.
Why is it illegal? Surely if it passes an mot Kph then it is legal.Remember it is illegal to drive here in Kph. As my Fiat Ducato is not the clearest to read, I have a “heads up display” in mph and kph. Therefore use the mph here and when abroad use the kph setting. I would speak to IH or Fiat for the answer.
I bought a cheap HUD from eBay to show kilometres when away in Europe. Saves messing about. Prefer my odometer in miles!!!Remember it is illegal to drive here in Kph. As my Fiat Ducato is not the clearest to read, I have a “heads up display” in mph and kph. Therefore use the mph here and when abroad use the kph setting. I would speak to IH or Fiat for the answer.
I doubt it.If it was all the foreigners would have problems as most don't get supplied dual marked speedo sRemember it is illegal to drive here in Kph.
All the left hand drive vehicles i had in the Uk did & most were also only kph speedos.Will it pass an MOT if only in kph.
