scotjimland
That was the cost of repairing the damage a wheel bearing failure caused ..
On journey home from France, we stayed at Calais for a night and caught LeShuttle home.. from Folkestone to home is only around a three hour drive, so no stops or comfort breaks
On a trip at every stop for fuel or break, I always check tyres and wheel hubs for overheating , but had no reason to stop on the last leg home.
Almost home, about 12 miles to go, the ABS warning lamp came on.. with hindsight , if I had stopped and checked I would have found the rear offside wheel bearing was hot.. but I didn't, thinking it wasn't dangerous to carry on.. brakes seemed ok.
When we got home I saw the wheel was covered in black grease and when I touched it was red hot !!
I called the garage and booked it in for repair and an MOT.
The garage called back and told me there was a lot of heat damage to brakes and hand brake cable and a melted ABS sensor, and would cost circa £700 to repair.
The bill for the wheel bearing repair was as follows
1. Wheel bearing £52.36
2. Handbrake Shoes £70.36
3. Fitting Kit £9.56
4. Handbrake Cable £32.38
5. ABS Sensor £73.94
6. Brake Discs, rear set £112.74
7. Brake Pads rear set £32.38
8. Labour 4 hrs @ £75 = £300
Total £683.72
Plus
Courtesy car hire £10
MOT £54.85
I'm now paranoid, to say the least, about wheel bearings overheating, Im checking all the time, even on the shortest trip..
Am now fitting wheel nut indicators that not only show if a nut is coming loose but also melt if they get too hot..
Amazon product ASIN B0BZ54RNLM
Total £683.72
Plus
MOT £54.85
