It was only a matter of time…. (1 Viewer)
Apr 3, 2022
41
44
Valencia, Spain
ItineoSB740 on order
Newbie
Sadly I had my first wrestle with a post today. It could have been worse but I’ve scuffed the skirt and wall of the MH. Does anyone have any good ideas about how to clean it up and repair the damage myself?
Feb 22, 2011
10,130
21,001
Newcastle under Lyme
Hymer B544 A Class
Since 2015
Most of that should polish out.
Is the trim dented ? It's hard to tell
Edit, I think it is dented, so probably mean a new piece of trim
Apr 22, 2018
6,930
12,773
Herts.
Adria Coral lowline
A good polish would remove the majority of that. I personally wouldn’t use TCut. Not good for plastics. There are better cutting compounds.
Jul 29, 2022
770
1,178
Watford, Hertfordshire, UK
Swift Kon-Tiki 599 S
Since 2021
So as it is a thin "layer of plastic" you may be able to remove by simply rubbing with your finger if thick enough or with a plastic scraper/credit card.
Use abrasives (T-Cut) very very gentle if required.
Jan 27, 2018
862
1,810
Aberdeenshire
low profile
Try a gentle household cleaner first like Pink Stuff or Jif type cleaner. If no success progressively use stronger ones but be gentle.
J
Apr 3, 2022
41
44
Valencia, Spain
Newbie
Thanks for the replies. I tried the credit card and it didn’t do anything. We’re en route to the UK at the moment so when we get there I’ll have a go with the Jif. I’m currently thinking if I ignore it, it might go away…I’m avoiding walking past that side of the vehicle!
Nov 3, 2020
1,341
2,262
Up the Hamble
Ace Siena
Since 2019
