We have a Yuasa battery charged by solar panel. our Finlux tv picture breaks up regularly. Sometimes if we put on the water pump or a light, but not always. The battery will be showing-a good charge. Has anyone come across this before?
If it's interference coming in along the cable, from the pump or a fluorescent light for example, then a ferrite bead will block it. It's a hollow block of special magnetic material. It's in two halves and clips round the wire. Even better to loop the wire through twice if it will fit. Sorry about the language in the link, I'm not in UK just now: something like this:
Achetez votre TRU COMPONENTS TC-KFR50 TC-KFR50 Ferrite clipsable 120 Ω Ø câble (max.) 5 mm (Ø x H) 13 mm x 12.5 mm 1 pc(s) bon marché en ligne. ✓ Des produits toujours originaux ✓ Des retours gratuits ✓ Un délai de réflexion de 30 jours.
