Is my Sprinter the only one that weaves all the time? (1 Viewer)
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
Following my recent trip down to Gibraltar, and back early I found that with all the Autovia and Autoroute driving, my wrists were very painful. With all the CONSTANT steering correction the Sprinter need to keep in the lanes, I was cramping and needed to keep flexing my hands. When a lorry went passed It was weaving badly from the slipstream hitting the back and then the front of the body. That was understandable owing to the large overhang on the front and rear of the bodywork on the Hymer, along with the short wheelbase of the 680 as against the 620. It is the constant corrections that get me all the time, an input one way and then pressure the other, just to keep in the lane middle. When I got it the tyres pressure were high at 80psi alround, so I looked in the manual and weighed it then also asked Continental the calculated pressures , I have 50 front and 65 rear as the setting they gave me. Any lower and the tyre would overheat. The tyres are wearing very well and at 26000 miles now they are hardly worn and show no wear patterns of undero or over inflation nor any tracking wear pattern.
The power steering is very light and there seems to be little self centring form the trail affect so it might just be that Sprinter vans are set up for Town and city driving only, and would need more trail to make them steady at motorway speed. Mercedes have stuck to the technical methods of auto lane following, and lane wander warning devices. I do not need warnings I just need the damned thing to be able to follow a straight line. Does anybody else have this problem? Or are there others with suggestion about how to make it go in a straight line.. I am seriously thinking about fitting NACA fittings all across the rear to change the aerodynamics, that might well help the lorry disturbances but not the super light steering, it seems the power steering get lighter the faster I go, I asked the MB dealer about it and they thought I was exagerating the problem, Well I never had a problem with my Chausson on a Ford Transit chassis , that was rock steady all the time including side winds.
43,320
49,406
You may be stuck in 'tramlines'
slight depressions in the road surface caused by trucks over the years.
Wheels on one side sat in the bottom of the depression and the other wheels slightly up the side of the other depression then swapping over repeatedly. Sort of sideways swinging effect.
Easiest way to find out is move closer to the lane edge out of the 'ruts' and drive there
Glandwr
Banned
Jul 10, 2014
1,057
3,301
the Berwyn Mountains
Hymer S740
since 2009
Worth checking your wt distribution between axles. Mine, a 616, wanders when it is light on the front axle, easily done with 800lts of water, garage contents and scooter on two bar rack all well behind the rear axle. Sidewind or buffering when passing trucks make it worse.
sdc77
3,244
4,550
Weardale, Co Durham
since 2011
So you obviously weighed the axles to get the correct tyre pressures. Sounds like you need air suspension.
Feb 24, 2013
13,077
101,439
Bolsover, Derbyshire
Hymer S800
not long enough
When you look at how much body overhangs the axle width it is no wonder
Ours had manually adjusted rear air suspension when we bought it, since added full rear air and our only issue which has not been improved is sideways rolling typically on sites, or rough roads at slow speed
Sounds like you might need to beef up the suspension in some way
Chris
21,051
278,587
None
10 years
One day I was driving our old Burstner in the New Forest and went round a bend that was slightly downhill. Not going fast , maybe 50 mph. I completely lost control of the van for a few seconds. I don’t know what happened but I think it might have been weight distribution or tyre pressures.
It was quite scary though.
If I hadn’t had driving skills better than Lewis Hamilton it could have been nasty.
Apr 17, 2016
5,943
35,336
South Coast
White One..
3 years….
Could have been the crates of beer shifting in the back making it unstable:)
MikeD
3,936
3,697
London
IH PVC
Since 2012
Our Autotrail Tracker on a Fiat chassis used to do that - we always thought we were going to the scene of a accident.
Air assist rear suspension cured it. Much, much nicer the drive after it was fitted.
Lenny HB
53,408
149,873
On the coast in West Sussex
Hymer B678 DL
Unlikely in Spain they don't have sh*t roads like us.:D2
Silver-Fox
9,264
29,063
Cheltenham Spa
Rapido
im a not so newbie
Ive got air on the rear and she is a peach to drive.
Only one hand on the steering lightly to hold a steady course.
If non of the above suggestions maybe one or both the front tyres have rubber issues that you can't see.
Jaws
23,836
72,457
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Two things spring to mind..
Some older Sprinters have shock absorbers that are next to useless..They really are not fit for purpose and certainly well below what the spring rate demands...
Second thing is to get the tracking checked.. The wheels might be TOO straight and a lack of toe in ( or on some weird vehicles toe out ) will mean the steering will not self centre but tend to wander.. The tyre wear would look fine
Feb 19, 2017
912
2,225
Leighton Buzzard
Ten years
This sounds good, we bought an elderly Hymer on a Sprinter base, it wandered terribly and was affected by passing large vehicles. Our garage suspected knackered front shocks, they fitted a pair of heavy duty ones made by Monroe IIRC. This did improve the handling by some margin, further improvement was achieved by learning to relax into the way these old Sprinters work, with lets be honest fairly unsophisticated suspension.
Jan 19, 2014
9,384
24,754
Derbyshire
Elddis Accordo 105
since 2014
I drove a new sprinter van circa 1997. The lad I was working with loaded a big AC unit right at the back doors. It handled exactly as you describe. Dangerous weaving :eek: German crap :LOL:
DuxDeluxe
14,658
72,726
Planet Zog
A woosh bang van
since 2008
Sprinter 519 with air assist at the rear. No issues at all. Much better ride than previous Ducatos
filopastry
1,016
1,738
london
littleun
newbie and learning every day
Incorrect tyres, right size incorrect sidewalls and compounds can have this effect. Also as previously mentioned too much weight in the rear of the vehicle will reduce weight on the front axle reducing the vans ability to track straight causing even small directional adjustments to become multiplied. Check not only the vans total running weight but also that of both axles. We have a laika 7.1G on a Fiat chassis, huge rear overhang, weight checked for run to Spain, full fuel and 50lts of fresh water, was 3560kg and she ran straight as a die. Fitting air suspension, whilst may redress the effect is not solving the underlying problem and for me.
As an after thought, check the rear axle mountings are not worn causing the rear axle to move slightly, or that there is excessive free play in the steering .
phil
GWAYGWAY
GWAYGWAY
4,213
3,306
Dover
Hymer ML I 580
4 years
Thanks for the suggestions,but it came from the makers doing it so I put airbags on it which raised the rear end and stopped the wallow but not the directional instability. Rail roaming on busy truck roads is certainly an issue as the sprinters are much narrower that the trucks so always has one side in the groove. I have the original Vancouver winter tyres which are like rock for comfort, but grip well in the wet and cold, they are wearing very well which is surprising for softer mix compound.. the van has Goldstein rear dampers so they should be OK but there is not much else I can do. It is very tiring trying to go a long way on motorways and straight roads but great on backroads. I still think they have not enough trail in the system to make it easy around town,and that is a manufacturing decision the makers made. If only it was possible to turn down the power steering it might help as it definitely gets lighter as the revs go up in cruise. My Ford Fiesta has electrically powered hydraulic pum and the ECU turns the pump down and effort goes up the faster the car goes making it more stable on higher cruise but light when manoeuvring in town and parking., the opposite of the sprinter chassis.
Body length and overhang must make a difference because of the swinging effect of the garage and airflow passed it.
Nov 25, 2013
1,119
1,761
kent
Swift Kontiki 669
Since April 2013
How much lateral overhang is there of the body to the wheels. Is the axle track of the 3.5t narrower that the 4 and 5 ton ? I once had an A Class where the wheels were inset from the body. It was horrible to drive never in a straight line!
Apr 11, 2015
5,408
55,076
hull
Laika Ecovip 300
We hired one a few years ago, it was the same. was told that it is a 'charectaristic ' of the sprinter.
Augusta08
964
1,425
Morbihan
Autocruise Augusta
Since 2001
I would suspect tyre pressure too low, are you measuring the 50/65 with them totally cold? I run 60/69 cold and they are 68/77 when they've warmed up.
