First night away without hook-up for some time. Leisure battery showing 13.5V when we pitched up, in the morning showing 12.2V. Battery is 180Ah. Just used lights, water pump, router, and presumably some heater fan in the night. Is this normal?
Oh! So how do I know what is happening with the battery?That will be the reading from your solar regulator and not the actual battery state.
Buy a NASA BM1 battery monitor...Oh! So how do I know what is happening with the battery?
Many members fit a battery monitor which more or less shows with reasonable accuracy the state of the battery. This would be the simplest way to know what your battery state is.Oh! So how do I know what is happening with the battery?
With respect ! That's not quite right Terry. Just because this battery has been taken down to 12.2 Volts does not mean it could be on its way out. This battery was measured whilst still connected and almost certainly has some sort of a load on it meaning its true state was unknown and would have certainly been higher if disconnected and rested. Also, a Battery test done by a local garage or Halfords is useless as a leisure battery test as the test only takes a measurement over a very short time and a knickered Leisure battery would probably pass this type of test. A different type of test needs to be undertaken for a leisure battery so the remaining capacity can be calculated.Hi if you have a 180 amp hr battery that means to take it down to 12.2 you have used around 80 amps overnight. That's a lot, even with blow air heating.
It could well be on its way out. To check fully charge when home, disconnect it from your van/ solar then check a couple of hours later then next morning,compare reading's
Or While it is off the van take it to a motor spares shopthey will have a tester that should tell you good or bad.
While I agree with some of what you say if the battery was fully charged ( we don't know if it was)assuming it was then 80 odd amps overnight is a big dropWith respect ! That's not quite right Terry. Just because this battery has been taken down to 12.2 Volts does not mean it could be on its way out. This battery was measured whilst still connected and almost certainly has some sort of a load on it meaning its true state was unknown and would have certainly been higher if disconnected and rested. Also, a Battery test done by a local garage or Halfords is useless as a leisure battery test as the test only takes a measurement over a very short time and a knickered Leisure battery would probably pass this type of test. A different type of test needs to be undertaken for a leisure battery so the remaining capacity can be calculated.
Why are you assuming that?assuming it was then 80 odd amps overnight is a big drop
I am afraid we can only assume as OP has not given enough information. Hence my suggestion to get it tested IF it has used 80 amps overnight. Since I am not in a position to see/ test it then assumption is all I have to work on. Not here for a argument the OP has enough information to make up their own mindWhy are you assuming that?
What with loads still connected and solarwe have no idea.
Perhaps it's time for the knowledge bot to appear![]()
I think you have hit the nail on the head! Too many assumptions to know what the true state of the battery was before and after discharge and at what time the reading of 12.2 V was taken the following morning.Why are you assuming that?
Just a thought for you . When you say the battery was at 13.5 Volts when you pitched up its quite possible this is because the alternator would be putting in around 14.4 V when driving to your location assuming the battery was not fully charged when you set off and the reading of 13.5V although a true reading from the battery could have hidden the fact it was not fully charged. (As said before, a battery needs time to settle without any load before you get an indication of its true state.) The other thing that could indicate a large draw from your battery bank is your heating fan. It could be drawing quite a few amps per hour depending on what type it is and how much heating was being circulated. I also wonder if the heating fan was still drawing current from your battery when you measured the voltage in te morning ! A battery monitor would definitely help you understand how much energy your battery is using at any one time and you could simply find out what draw is being taken from the battery by switching your services on and of one at a time and noting the reading on your battery monitor. Depending on the amount of Solar you have and the state of your battery it may take quite a while to fully charge your battery bank. The voltage alone without a measure of capacity used, can be misleading.Hi all. Sorry I've not responded to all your interesting suggestions but we've been out and about. Back now.
To respond to some of the points raised. The 12.2V reading was at around 8.30 in the morning. It started to increase before we left the site and had reached 12.7V as we set off at 10.30. Sunny most of today, plus 2 x 15 minute runs on the road. Reading was13V at one point. Now back on site and reading is 12.7V after about an hour pitched up. Nothing drawing other than control panels and router. Heating is off.
But as mentioned by others, the reading is only what the panel is giving.
Once the sun has gone is it possible that the reading will rise if the battery is fully charged?
As Terry said 80 amps is a lot of current to have drawn overnight, if that assumption is correct.
That's not going up much voltage wise. I'd expect it to reach 14 point something with solar all day. Could be the battery is not very charged up and the sky is cloudy, could be battery faulty, solar not big enough etc etcHi all. Sorry I've not responded to all your interesting suggestions but we've been out and about. Back now.
Right, that makes some sense. Whenever I've looked at it on the storage compound, (i.e. after several weeks of no use), it always shows around 13.5V. Presumably the reading off the solar. At this moment, 17.15, still daylight, and after having been run out today, it's showing 12.7V. I will note down the readings as the daylight disappears, through the evening, and tomorrow morning.12.7 is a full battery. Anything above 12.8 will be either your solar or alternator if engine is running. No good looking at charge within a couple of hours after a run or daylight.Once dark look then and next morning to get a indicator as to charge.12.2 is a almost half depleted battery reading. Only sure way is to get a test done.
Well, I will definitely be getting a battery monitor, as I have no idea what is going on at the moment. The controller is a Schaudt LR1218, which I believe is PWM? Last night when we turned in at about 23.00 the control panel was still showing 12.2V, which it had shown since 21.00. This morning at 07.30 it was still showing 12.2V, and as I write has not changed. It is overcast though? I'm not really happy to carry on not knowing whether we may be damaging the battery, so I'll be looking for EHU for the rest of the trip. When we get back I'll try to do a proper test on the battery with no load etc. I may need further advice on how to safely disconnect from the solar.What type of solar controller is it? PWM or MPPT? If the label doesn't tell you, what make/model is it? As Richard n Ann says, it looks like you're not seeing voltages of around 14.5V, which is what I would be looking for to see if the battery is being fully charged.
When fully charged, the charger drops the voltage from about 14.5V to about 13.5V. You don't say what wattage the solar panels are, but it takes several hours at around 14V to charge a battery, especially if the solar panel is around 100W and the battery is 180Ah.
One possibility is that the battery is just not getting charged enough, and is consistently not near 100%. This is bad for the battery if it happens over more than a few days. Lead-acid batteries, including gel and AGM types, need to be 100% charged regularly, at least once a week, or they gradually deteriorate due to sulphation.
To repeat what others have said, the voltage of the battery while it is charging or discharging is a very misleading indicator of the state of charge. A proper battery monitor, like the one in Richard n Ann's post#8, continuously measures both amps (in and out) and voltage, and has a microchip with timer that computes the charge into and out of the battery to find the total remaining charge.
I don't know about this particular controller, but PWM controllers generally have a lower voltage than the MPPT type, especially in overcast conditions. I'd go for EHU at least once a week, and if the weather improves you might not even need that.The controller is a Schaudt LR1218, which I believe is PWM? Last night when we turned in at about 23.00 the control panel was still showing 12.2V, which it had shown since 21.00. This morning at 07.30 it was still showing 12.2V, and as I write has not changed
Yeah that makes sense. What is still worrying me is the drop off in indicated voltage. (I understand the control panel is not simply showing the battery condition). Last night we went from 12.7V at 17.30 to 12.2V at 21.30. With a 180Ah battery this seems worrying. Nothing heavy duty was in use.I don't know about this particular controller, but PWM controllers generally have a lower voltage than the MPPT type, especially in overcast conditions. I'd go for EHU at least once a week, and if the weather improves you might not even need that.
Do you know what the current drain was? Ours drops continuously during the night as there is a small ½ amp load 80ah battery drops by about 0.1v. You can see it dropping steeper on the left hand side when the TV is on (total load about 2a)Nothing heavy duty was in use.
This seems to confirm your battery is not fully charged and the voltage your seeing during daylight is from your solar panel and as soon as it gets dark your seeing the battery voltage without any solar support. You do not say how much solar you have and I suspect its not enough to fully charge your battery bank. As has already been advised, get onto hook up asap and make sure your battery gets a full charge. You, like most of us learn from these experiences and will overcome these problems. Remember you can never have too much solar.Yeah that makes sense. What is still worrying me is the drop off in indicated voltage. (I understand the control panel is not simply showing the battery condition). Last night we went from 12.7V at 17.30 to 12.2V at 21.30. With a 180Ah battery this seems worrying. Nothing heavy duty was in use.
Battery Voltage Chart | ||
Volts | % | |
12.7 | 100 | |
12.5 | 90 | |
12.42 | 80 | |
12.32 | 70 | |
12.2 | 60 | |
12.06 | 50 | |
11.9 | 40 | |
11.79 | 30 | |
11.58 | 20 | |
11.31 | 10 | |
10.5 | 0 |
