- Jul 17, 2009
- 192
- 163
This only really happens when you've done something to add moisture to the air. Like breathing or cooking.It will get damp in there as warm air holds more water, you may come back to a bath in the van instead of a shower….![]()
I use a 4 foot long tube heater mounted on a board then plugged into a thermostatic switch set to 9 degrees. I don’t drain down. But use the Van in Winter to get to the sunWould you leave your MH on electric hook up with a small thermostatically controlled oil filled radiator for two weeks, would it be safe ? We have a battery Master with two hab batteries fitted. Forecast is for -7C while we are away !
The only thing I'd add is to make sure that any stuff left in there (electrical equipment etc.) can handle the anticipated temperaturesWell thanks everyone for all that. The water is already drained including the boiler. On your comments I have decided not to bother with any heating, on my return from West Africa I am going up to Scotland in the MH, if I find there are any weather related issues regarding water pipes etc I shall be writing to you all personally !
Mitch
Not if you have a proper winterised motorhome with a double floor where the heating ducts/pipes follow the water pipes.If you put a heater inside the van, the heat won’t get to where the water pipes/boiler is, it will just heat the living area. So pipes and other items can still get freezing problems.
Don’t rely on hook up , what happens if you a power cut , we was recently left with no power for 3 days due to storms granted we live rural.Would you leave your MH on electric hook up with a small thermostatically controlled oil filled radiator for two weeks, would it be safe ? We have a battery Master with two hab batteries fitted. Forecast is for -7C while we are away !
That is exactly what I’m saying. On a motorhome the pipes and heating ducts are run together, so are not effected by the frost.Not if you have a proper winterised motorhome with a double floor where the heating ducts/pipes follow the water pipes.
Sorry, I misread your post.That is exactly what I’m saying. On a motorhome the pipes and heating ducts are run together, so are not effected by the frost.
BUT if you just wack a small electric heater inside the hab area it won’t be with the pipes. So you are leaving them to freeze. Thinking they’re safe.
I just purchased that same Dimplex heater as additional heating for my PVC, I do have a diesel heater in there but reluctant to leave it on all night, hence the Dimplex. Tested at home and does kick out a nice bit of heat even in a large room. And its thermostatically controlled.Try something like this , oil free was recommended to me by carolyn
No chance of leaks , she was right it been knocked battered and slip down the van when travelling, still going and economical my pvc get rather warm rather quickly
Ticking away nicely in my van right nowI just purchased that same Dimplex heater as additional heating for my PVC, I do have a diesel heater in there but reluctant to leave it on all night, hence the Dimplex. Tested at home and does kick out a nice bit of heat even in a large room. And its thermostatically controlled.
