NicandJay
- Nov 24, 2017
- 658
- 3,390
- 2021 Burstner TD680G
- Camping , caravanning, campervaning for 10 years
From the unreliable figures supplied by dealer with upplating done before collection.... I know they cant be relied upon but given the room for a margin of error I think we will be fineWhere does your 890kg payload come from?
No mention of the wine in there JayOk one for PVC owners on the forum please... is a payload of 890kg sufficient before I add accessories of a roll out awning, solar panel, additional hab battery. I run with 2 x 11kg gaslow system, a wife, driveaway awning plus 2 e bikes, 2 x 10kg dogs.
What are your thoughts?
TIA
Upplated to 3850? I think your payload should be absolutely fine.Globecar 640 summit Prime
To get that payload on a Globecar it must have been up plated?Globecar 640 summit Prime
It is probably me, but I am not seeing the difference. What am I missing?If a Brit van 500 probly OK a German van you need 700,
That's great and really informative. Thanks for replyingOk, I'm a rank amateur.....
I suggest your list above would come in some way under 300 kg, leaving you well over 550 kg for the rest.
That's a lot of leeway.
You'll have to add water, wine, diesel, food, clothing, wine, paracetamol, chairs, table, tools, wine.
Can anyone suggest anything significant I've missed here.
Nowhere near 500 kg though?
Then weigh front and rear axels individually on a weighbridge.
We have a 6m PVC and, full of everything, come in way under maximum allowed (3.5t).
I was puzzled initially but the OP said “before I add accessories”. UK vans tend to include lots of standard accessories. The Germans don’t, they give you a long list of options so that you can choose what you want but this means you have to allow for these in the payload calculation.It is probably me, but I am not seeing the difference. What am I missing?
German vans have a basic spec then it's up to the customer to choose his options, The given payload is based on the basic spec so every option reduces the payload. You normally can't buy them without the basic comfort/chassis pack which is an option, TV is an option, oven, fog lights, and loads of other things. If you buy a German van you normally end up spending an extra £10k to £20k on options.It is probably me, but I am not seeing the difference. What am I missing?
What is the manufacturer MIRO and what does it consist of? On the Adria Twin 640 we are getting the MIRO (2910) includes driver, 90% diesel, 20% water, tool kit, 16kg gas cylinder, and a mains cable reel. I’ve calculated the following additions. All inclusive pack 93kg, aircon 33kg, extra battery 25kg, solar panel 10kg, wife 65kg, bikes 24kg. That leaves me with about 334kg to play around with, more than enough for us. Of course the MIRO figure might not be accurate but a trip to the weigh bridge will check that.
Yes agreed. Not our first moho but our first pvc and was just a little concerned before putting down depositPayload can be as much as a length of string.
It requires discipline. If you are too carefree, it will build up and you'll be over (just as I suspect many are).
Do you really need two awnings? Forget the roll-out and see how you go. You may need that saving for something else.
Second battery? Likewise, or look at Lithium.
The calculation is not made easy because of all the smoke 'n mirrors surrounding what things are included or not in declared weights.
It looks like you'll be OK but I'd start with the minimum of add-ons and check at a weigh bridge in your real 'running order' to see how much spare you have.
Wait for experience to tell you what's really necessary. You can spend a lot on attractive toys that you don't make good use of. If you tread carefully you might save a lot of ££ and Kg.
If you need to, I think there is a tolerance before you're declared overweight. You could add that margin to your allowance if you had to. Someone will say, but check it out if you need to use it.
Try not to fret. Get out there and enjoy it.
Less chance of forgetting where something is if there are fewer places to hide it.If the proposed vehicle is a popular one, it must clearly be manageable to live within its confinements of weight and space.
I was attracted by the idea of a PVC but decided that we are not tidy enough:
You have to put everything you take somewhere, pack it in tightly, and remember where you put it.
Good Point!Less chance of forgetting where something is if there are fewer places to hide it.
We are thinking of a Van-Star for our new Adria Twin 640 (when it arrives) Similar to the busbiker, the Van-Star weighs 45kg, if that helps? It's a hefty piece of kit!No bikes or back rack (we were going to have a busbiker towbar rack fitted),
