Hi All as anyone used a WiFi only ipad for a Satnav. I know you need a cellular one but wanted to use my phone as hotspot as I have unlimited data and wondered if it worked.
Thanks Patio.
Thanks Patio.
Thanks I was thinking ofIf using a satnav program like Sygic (what I use) you don’t need any Wi-Fi or data as the maps are on the device. So you could just get a remote GPS sensor. I join my iPad to iPhone using hotspot, or most of the time it’s on the vans miFi.
Thanks Patio.
I used to use copilot on my ipad through the van mifi but they changed their owners and the whole thing went t1t$ up so ended up using a grunt garmin stick on and still using it 2 years later.Thanks I was thinking of
co-pilot.
I tried this with a WiFi only iPad using Waze and tethered to my iPhone but I found that the phone does not share its gps with the iPad so it didn’t work. Went for Apple car play instead.i use co-pilot on my ipad but you do need GPS if your phone will act as the gps sensor for the ipad then your in. i am not sure if that will be the case though.
can you not try it out before subscribing to co-pilot.
Yes, I have done it many times…
Thank you.I use my iPad 11 as a satnav connected to my Samsung phone or my onboard mifi device (H5577) with data and hotspot turned on. it works just as well on either. Nice thing about using the iPad is I can access google maps and plan the route I want to take and not what the satnav device chooses.
I have been using my iPads with the Garmin Glo for several years. Works fine for me with Copilot and also with Google maps navigation.So after a bit of research I have came up with two options 1 there is a Garmin Glo 2 which is a satellite receiver and works with Bluetooth which can be used basically anything with Bluetooth I have seen it on youtube working with a none cellular iPad and it works well.
Nice one thank you.I have been using my iPads with the Garmin Glo for several years. Works fine for me with Copilot and also with Google maps navigation.
