Invisibrake problems (1 Viewer)
Jun 11, 2024
Roller Team 747
Hi I have a Toyota Aygo that I tow with an A frame behind my motorhome . The system was fitted to the car by LNB towbars Bristol, it incorporates a power braking system known as an invisibrake. The system keeps losing pressure making braking very inefficient and preventing the stop lights on the car from working when being towed . I have contacted the installer for advice but as I bought the car and system second had they have been less than helpful. Please can anybody offer any advice.
Dec 12, 2010
5,544
22,747
Cumbria
since 2011
Never seen the system before, but a quick Google would have me pressuring it up and then go around with some soapy water on all the pipe joints/connections and cylinder (or even have a good listen for air leaks) If you don't find anything there, I'd be stripping the box apart as all that can be left is the non return valve in the compressor itself that's maybe letting air bleed past it ?
Nov 13, 2011
1,545
4,820
Lincolnshire
PVC
30 years
There appear to be two pressure systems, one to operate the brake pedal and one, a vacuum, to evacuate the servo. If you are getting poor performance, it could be a loss of vacuum at the servo.
Geoff
Nov 13, 2011
1,545
4,820
Lincolnshire
PVC
30 years
There is a You Tube video of an installation, would not allow me to link it. Just search for Invisibrake.
Geoff
