Inverter reset
Citroen Dave
Citroen conversion
I have fitted an inverter to my van. Stupidly I did not check battery voltage so have 32 low battery voltage fault showing. I have disconnected battery for 1hour to see if fault will clear to no avail battery now full but I cannot clear this fault to be able to use inverter. Any ideas great fully received. Thanks in advance
If you can post a photo and name of inverter I’m sure someone will be able to assist😊
Battery now fully charged will get replacement bstteries. Once I find out how to reset the inverter. As everything in van runs off inverter except hob can't use van until fixed.
depends on your inverter.
try and press the on off button if it doesnt have a red reset, for 10 -15 seconds
